LabWindows/CVI
Where is the LabWindows CVI 7.0 ActiveX Server Documentation located ?
Where are the methods exported from the CVI 7.0 ActiveX Server documented. I can create the FP easy enough but it would be nice to have documentation on all the methods available. All I would like to do is to programmatically tell CVI to add a variable to watch and then delete it and remove the watch window probably this could be accomplished using CVI_FakeKeyStrokes. Any examples available that may be of use ?
(3,053 Views)
Hi
Documentation for ActiveX Server is located in the help files. To access them go to Help>>Contents and under the Index tab search for ActiveX. Let me know if you need more documentation. Thank you.
Robin
(3,053 Views)
Robin,
Thank you for the quick response. I checked the help files as you recommended but the methods that are available from the CVI 7.0 ActiveX Server are not documented there. Help and or examples on functions such as CVI_FakeKeyStrokes that are exported from the CVI 7.0 Server are not available. A "FP" may be created to call the methods of the CVI 7.0 ActiveX Server by using the generate ActiveX controller wizard.
I have not been able to find good documentation on all the methods contained in the server or examples of usage.
Tom
(3,053 Views)
