LabWindows/CVI
While compiling with Labwindows\cvi I get a warning: Unexpected trailing tokens on diretive line ignored.
When I click to go to the line of code that contains the error, CVI takes me to the first line of the *.c file. I get this warning for about 3 of my *.c files in my project, but not all of the .c files in my project.
(4,161 Views)
Did you try to put a comment on a directive line such as a #define line? That may cause this problem.
Perhaps you could attach the top 25 lines or so of the .c file that's giving you the problem.
(4,161 Views)
There are several causes for this warning. The most common ones are probably
a) specifying more than one file on #include
#include
The second file is ignored. Only one include file per #include is allowed.
b) specifying an identifier (from #ifdef) after #endif
#ifndef __ABC_H__
#define __ABC_H__
#endif __ABC_H__
__ABC_H__ after #endif is simply ignored. Write #endif /* __ABC_H__ */ instead. This usually is a problem in include files.
c) undefining several identifiers at once
#undef A B C
B and C are ignored. Only one identifier per #undef is allowed.
(4,161 Views)
I have an identical problem with my code.
I get the warning to the first line with standard include (e.g. #include ) but also if the first line is blank.
I include some lines of my code (note that the first line is blank).
Thank you.
(4,161 Views)
