Why can't I find "dataacq.h"?
I've installed LabWindows CVI and I need to use the file dataacq.h. I believe this file is supposed to come from the Ni-Daq software. I installed Ni-Daq version 6.5.1, and ran the setup, but it didn't seem to make this file available for LabWindows use. Thanks for your help.
(3,643 Views)
If you go back to NI-DAQ setup, you should see LabWindows/CVI support in the list of components to install. Check the path where it is installing CVI support and make sure it is your current CVI directory and complete setup.
If you are still having problems, contact our tech support engineers for help via http://www.ni.com/ask.
Best Regards,
Chris Matthews
(3,643 Views)
