If you go back to NI-DAQ setup, you should see LabWindows/CVI support in the list of components to install. Check the path where it is installing CVI support and make sure it is your current CVI directory and complete setup.
If you are still having problems, contact our tech support engineers for help via http://www.ni.com/ask.
Best Regards,
Chris Matthews
