LabWindows/CVI
Why does CVI have functions that duplicate the ANSI C file manipulation functions (ex: Openfile)?
Why does CVI have file manipulation functions that seem to duplicate the functionality of the ANSI C functions?
Is there an advantage to using the CVI functions?
(3,544 Views)
Accepted by querty999
As CVI was released (1987) before the ANSI-C standard came out (1989) perhaps the question should be the other way round!
In those early days, CVI was intended to be multi-platform, so it made sense to develop a set of libraries that operated in the same way across the various computers that it was targetted at. These days, focus seems to be mainly on Windows, so this early philosophy is somewhat redundant, especially, as you say, with the widespread adoption of ANSI-C.
Personally, if there are similar functions in CVI and ANSI, I will go for the ANSI ones every time for portability reasons, but then again I write code in a number of different programming environments.
JR
(3,536 Views)
 JR,
Thanks for the historical/legacy perspective.  Very helpful to newcomers.
(3,531 Views)
