LabWindows/CVI
Windows 95 generates error: Invalid page fault in module
What is the typical reason for windows to generate an Invalid page in module application.exe?
(3,102 Views)
There are many reasons that a page fault can be generated.
Accessing memory that you have no permission to access is the typical problem I seen.
Without more specific details it would be difficult to diagnose.
Do you have the problem when running just your application or while in the LW/CVI Debugger?
(3,102 Views)
Invalid Page Faults are hard to debug. Especially if they only happens in release configuration. One technique that I find useful is to write to a file the function that you are about to execute. That way you can read the file and find out what is the function generating the crash.
I hope this helps.
Juan Carlos
N.I.
(3,102 Views)
