LabWindows/CVI
Workspace settings (multiple DLL projects with one main project)
How to set up an workspace had one main project and several DLL project? So that the DLL projects must compile first before CVI compile the main project.
(3,406 Views)
hi,
    I think there is no way to set dependecy between multiple projects.But, you can add multiple project to one workspace by Menu Edit->workspace and then use Menu Build->Batch Build.
(3,390 Views)
I am using the build batch option too.  Suggestion to NI develop feature similar to MS visual studio.
Thank you.
(3,382 Views)
If you want to suggest a product improvement, then the LabWindows/CVI Idea Exchange is the right place to post!
(3,377 Views)
