LabWindows/CVI
PXA N9030A
I am and new user to PXA N9030A I use labwindows. I have downloaded the msi installation file and installed I can see the AgSan component
under IVI solution and use it API to command the instrument but nothing happens.
I did setup the GPIB address and disabled the GPIB controller in the instrument and can watch the commands in the GPIB spy to be in the bus.
At initiation I get the error message unknown resource.
What should I do it there some set up in the instrument that I missed?
Smiley Sad
Eugen
(2,996 Views)
Accepted by topic author emorales
Did you install IVI Shared Components?
http://www.home.agilent.com/upload/cmc_upload/All/readme_ivi_matlab_AgXSAnLTEFDD_1_0_7_0.txt?&cc=US&...
Did you install Agilent IO Suite or NI-VISA ?
(2,988 Views)
