07-17-2012 01:29 AM
I am and new user to PXA N9030A I use labwindows. I have downloaded the msi installation file and installed I can see the AgSan component
under IVI solution and use it API to command the instrument but nothing happens.
I did setup the GPIB address and disabled the GPIB controller in the instrument and can watch the commands in the GPIB spy to be in the bus.
At initiation I get the error message unknown resource.
What should I do it there some set up in the instrument that I missed?
Eugen
Solved! Go to Solution.
07-17-2012 01:15 PM - edited 07-17-2012 01:16 PM
Did you install IVI Shared Components?
Did you install Agilent IO Suite or NI-VISA ?
