LabWindows/CVI
Write a digital channel
I have to command a relay (5V) so i have to use labwindows to create a CVI project and call it from Test Stand.I tried to use the Write.Dig.Chan from find examples in CVI but it dosen't work!!!!!!
Could you help me please in modifying this code to call it from Test Stand and generate the 5V.
I'm using Labwindows CVI 2010, Test Stand 2010 ,and NI PCI 6220.
(3,803 Views)
Hi PFE,
What specifically in your WriteDigChan example isn't working? Once your CVI code is functioning properly, you'll be able to call it from TestStand using the CVI module adapter to perform your tests.
Best,
(3,790 Views)
Accepted by PFE
Thanks for responding me. I solved my problem.I did it with Labview it seems to be easier and functionnal.The snapshot shows the the VI that works efficiently:)
(3,779 Views)
Hi PFE,
Glad things are up and running!
Best,
(3,766 Views)
Hi Courtney L,
Thank you :))))))))))))))
(3,761 Views)
