LabWindows/CVI
XML "strange" characters handling
Hello
From what I know XML tags do not suport spaces " ", numbers, or "<", ">", "ä", "ö", "ü", "ß", etc...
Also some characters are not supported even as tag values "<", ">" ...
Is there stilll a posibility to have them as tags? maybe use double quotes <tag"ä">value < something</tag"ä">?
Thank you.
(3,178 Views)
Well, I think in HTML, the ">" is &gt (greater than) and the "<" is &lt (less than).  In a similar manner, I think I recall &sp is " ".
I'm sure the others are possible too, but these I think should work.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,175 Views)
