LabWindows/CVI
Plot to excel copy graph
Is it possible to add a graph in excel, with all the plots (4 in total)......... I mean to copy the graph and not the trace data, so i can insert it in user defined destenastion (RC)....
I can communicate with excel already..... (reading out and writing in data)
(4,184 Views)
Hi Marten,
You can use the following function:
int GetCtrlDisplayBitmap (int Panel_Handle, int Control_ID, int Include_Label, int *Bitmap_ID);
To get a screenshot image of the current appearance of a control on your user interface. With ActiveX you sould be able to insert this as a picture object in to Excel? This is then a static image in Excel.
If you like to get a native Excel Graph the you should first copy the trace data to excel and then create a Excel Graph (again using ActiveX) that displays the data as a Graph.
Hope this helps
Kasrten
(4,150 Views)
It may be a static image.... But how can i do this in labview.... because the sample code is visual basic/C++? and labview is so far i know only blocks so i can't use that code??
Or can you use code's in labview???
Message Edited by marten on 03-06-2007 04:37 AM
May also (favorit) the same style as the copy as simplified image ...... Because the style of it fits with that of my template........
Message Edited by marten on 03-06-2007 04:43 AM
(4,148 Views)
Hi Marten,
You posted this on the LabWindows CVI Forum board which is a ANSI C ADE / Compiler, please post LabVIEW Questions on the LabVIEW Forum here.
As for you question, in LabVIEW you can use a invoke node linked to a Graph with the Methode 'Get Image' to get the static image of a Graph.
Hope this Helps
Karsten
(4,138 Views)
