LabWindows/CVI
inline asm in CVI - integration with Execryptor
Hi all,
I'm trying to "prepare" my application for being processed by ExeCryptor (an utility that parse the exe file and encrypt some portion of code, properly marked).
Basically this utility requires that in some portion of your code you have to put special markers (made up of a fixed sequence of byte).
The suggested method for putting the special markers is to define a macro like this:
#define CRYPT_START { asm {                           \
    DB 0EBh, 006h, 0EBh, 0FCh, 0EBh, 0FCh, 0FFh, 0F8h \
and to put the CRYPT_START where you want to start encryption.
I've read in the forum that CVI doesn't support asm. Is it correct even in the latest CVI release?
Does anyone know a workaround in c to hardcode a sequence of byte at a certain point of your code?
many thanks in advance
cheers
(4,587 Views)
Hi Davide,
I've found these few lines about your problem and I think that for now there is now integration:
CVI does not support __inline and __asm modifers and keywords, since CVI is not an optimizing compiler and cannot compile assembly code, respectively. Unfortunately, there are no workarounds to that, since CVI is not designed to handle these operations.
If it doesn't change the behavior of the third party API, you can ignore __inline modifiers using "#define __inline" and ignore __asm keywords and the assembly code using #define and some regular expression tricks. However, ignoring the assembly code will most definetely change the behavior of the code.
Marco
(4,557 Views)
I may be way out to lunch here, but what if one were to use an external compiler, now supported by CVI? (Under Options>>Build Options).
(4,545 Views)
