03-05-2013 04:03 PM
Your example on Sharing Memory is very interested. (http://zone.ni.com/devzone/cda/epd/p/id/2394). However the zip file is missing the "sharemem.h" file. Can someone please add it?
Solved! Go to Solution.
03-05-2013 04:57 PM
I cannot run the example here, but as far as I can understand from the files included, sharemem.h is the include file associated with the .UIR with the same name. You can try making the system to recreate it by simply saving the .UIR file (if save is not enabled, simply move one control or make another cosmetic change so that file >> save option is enabled): this should fix the problem.
03-05-2013 05:07 PM
Well Roberto, you made my first NI post a pleasant one. Your suggestion worked perfectly!
Thank You!
Scott
03-06-2013 02:23 AM
You're welcome! ![]()
03-12-2013 10:26 PM
well
