LabWindows/CVI
about discrete tests.
Hi....
Am doing one program, In that i am checking the output port by verifying the each  single line ID in the test panel.my question is that can i able to check entire port itself(in the test panel we are having output port3,4,5, each port having 8 line IDs),because by checking each line ID ,it takes more time....can u give any suggestion. I am using discrete NI 6527 DAQ in my PC.
Regards
balaji
(3,085 Views)
Hi Balaji,
If you are using LabWindows CVI there are examples that show you how to read or write from a digital port rather than each line individually. If you go to Help>>Find Examples>>Hardware Input and Output>>DAQmx>>Digital Measurement>>ReadDigPort.prj, or Help>>Find Examples>>Hardware Input and Output>>DAQmx>>Digital Generation>>WriteDigPort.prj. I hope those help.
Ima
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(3,056 Views)
