about nonfatal runtime error in CVI
Good day
My program:DBNumberOfRecord() gets a nontatal runtime error when I debug it, if I press continue it gets normal work. So I think the error dialog is improper, but i cannt skip it.
Can i skip the error when debugging? thank you!
(5,326 Views)
Provided you are sure this error is meaningless, you can skip all library errors with Run >> Break On >> Library Errors menu option
(5,323 Views)
Accepted by justtin
During debug of an application under development it may be excessive to filter out all library error messages. In this case you can enclose your faulting instruction between a pair of SetBreakOnLibraryErrors () calls that disable and then re-enable popup error messages.
(5,317 Views)
Thank you for your answers!
Using the function SetBreakOnLibraryErrors solved my problem properly. Thanks.
(5,309 Views)
