LabWindows/CVI
about wait function and parallel coding
Hi all,
  I am porting a labview code to CVI. In the LV Code, I use Wait to delay some times in millisecond . I wonder for CVI, should I replace theat Wait with Delay(double) in CVI?
Second question. In LV, all the code in the same frame will be executable in parallel. But in CVI, science it is c-based language, I guess all the code are run in series, is that true? How can I make some codes in CVI running in parallel? THanks.
(4,344 Views)
Accepted by dragondriver
These are frequent questions and you will easily find answers yourself by searching.... Smiley Wink
For the first issue, see e.g. here, for the second see here
(4,338 Views)
