LabWindows/CVI
afficher les accents
Bonjour à tous.
J'aimerais savoir pourquoi dans un nouveau projet labwindows, si je lis un fichier pour remplir un ringBox, les accents ne sont pas affichés correctement.  Le même code dans un autre projet, je n'ai pas ce problème.
Merci
(2,641 Views)
So you are saying that:
  • Reading the same file
  • On the same machine
  • With different applications developed with the same version of CVI
gives different results?
That's weird! I would double check the code the see if it's exactly the same or not.
If on different CVI releases: which one is working and which one is not?
(2,614 Views)
I did double check and yes, same code.
When i'm in debug mode, I can see that the reading of the file is good.
When it's time to write it to the interface, then I have weird characters.
I'm gexpecting example : école
I see :
(2,592 Views)
Here is a picture in debug
2021_12_02_10_43_48_c_developpement_labwindows_projets_micman_micman.cws_micman.c_.png
mode
(2,543 Views)
Found my problem.
My ini file that I was loading was in UTF-8 and was causing me the problem.
I encode the file in ANSI and no more problems with symbols.
(2,541 Views)
