04-07-2015 12:09 AM - edited 04-07-2015 12:19 AM
Let's see: your version is very old, I'm not sure I can remember how to do!
In the project window (where source and uir files are listed) you should have an Instrument menu with a Load... item inside: that should be the place where to load the Programmer'S Toolbox. Alternatively you should have a Library menu with a Customize... option inside: instruments can be loaded there too.
Search the product help: the process should be well described.
04-07-2015
01:03 AM
- last edited on
06-10-2025
10:32 AM
by
Content Cleaner
I managed to find an online copy of CVI 5.5 user manual: you can download it from this page.
The process of adding instruments is described starting at page 3-35
09-23-2015 04:11 AM
Hi RobertoBozzolo,
can give me link sample example for EnableExtendedMouseEvents
Thank you
Sudhir Acharya
09-23-2015
05:55 AM
- last edited on
06-10-2025
10:32 AM
by
Content Cleaner
While searching for an example of EnableExtendedMouseEvents I got in touch with the attached sample program that does exactly what you are searching for: it updates a graph while a button is continously pressed. You won't be able to execute it since it's for CVI2009 (you can look if it exists a version for your release on your disk: I would search in the help for the command), but you can look at MoveCB () function to understand how it works. Basically it intercepts EVENT_LEFT_CLICK to mark the start of the mouse press and EVENT_LEFT_MOUSE_UP to mark press end.
You can also look at the example shown on this page: it's rather obscure since you can only have program output in the debug window but it's another piece of code to study. To execute it you will probably need to rebuild the user interface in CVI5.5: it's basically a simple panel (name: PANEL) with a canvas inside (name: CANVAS; callback: CanvasEvents) and a quit button (name: QUITBUTTON; callback: QuitCallback).
** EDIT ** I already pointed you to the second example some posts ago: I leave it since I am adding some infos tha could help you to to run it in your system.
09-23-2015 08:22 AM - edited 09-23-2015 08:37 AM
thank you sir
i wil try
09-23-2015 08:30 AM
Inside the attachment to my previous message the whole project is present: source, include, UIR, PRJ and CWS files.
How did you extracted the files from the compressed file?
