bad fonts? uninstall cvi rte?
I have several cvi programs installed on a 95 machine
the fonts went askew/fuzzy in the runtime gui?
fonts are ok in the ide.
I replaced in cvi rte folder, still bad
i wanted to uninstall reinstall runtime engine
seem have a no remove facility
or does i? help?
(3,436 Views)
The CVI Run-Time Engine does not provides an individual installer; the required dlls are installed by the IDE. There is a possibility here; you may want to downgrede the CVI run-Timeengine installed to see if these font effects go away. You can go to the windows\system32 folder and delete the cvirte.dll from there and delete the cvirte folder as well. Then you can download the CVI run-time engine installer from the web.
I hope this helps.
Juan Carlos
(3,436 Views)
Herley,
Please refer to the following post for a fix to this issue (found to be a bug in CVI 7.0):
(see last post in the thread below):
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000E8B30000&UCATEGORY_0=_318_&UCATEGORY_S=0&USEARCHCONTEXT_TIER_0=0&USEARCHCONTEXT_TIER_S=0&USEARCHCONTEXT_QUESTION_0=bold+font+95&USEARCHCONTEXT_QUESTION_S=0
Best Regards,
Azucena Perez
(3,436 Views)
