callback passed to ConnectToTCPServer is not being called...
Here's my code:
static int CVICALLBACK tcpCB (unsigned handle, int event, int error, void *callbackData);
iRet = ConnectToTCPServer (&gModem.TCPHandle, gModem.TCPPort,
            gModem.Number, tcpCB, NULL, 5000);
The tcpCB is never getting called.
I tried slightly different decrares for the callback function - nothing.
Help is appreciated.
(3,710 Views)
Are you getting an error return from ConnectToTCPServer() ? Your call looks OK in principle but there may be a typo somewhere in defining port numbers, server names or whatever. Is the Server you are trying to connect to on the same PC or across a network - maybe a firewall is getting in the way?
JR
(3,708 Views)
The device I'm connecting to is on a small network segment,
no proxies or gateways or anything.
I can connect, I can write and read just fine, no errors.
(3,707 Views)
So I'm guessing that you are using ClientTCPRead() to retrieve the data in some kind of timed/tight loop? This might be having an effect on the callback structure - in my programs I only call ClientTCPRead() from within the callback itself, when the TCP_DATAREADY event is received.  IIRC, you will only get callbacks triggered if there is a ProcessSystemEvents() or similar within the program - if you are running in a separate thread this could be the reason no callbacks are being generated. Maybe someone from NI with inside knowlegde of the TCP callback structure can advise?
JR
(3,698 Views)
ProcessSystemEvents() did it, it started firing the callback.
Strange thing is, after I commented out the
statement, the callback is still working!
Mystery... But it seems to work now, so thank you very much!
Gene
(3,695 Views)
