calling labwindows dll with callback from c# with delegate
I am currently trying to 'consume' a dll written in LabwindowsCVI which uses callbacks in a c# windows application using delegates, does anyone have any small working examples of how to do this ?
Paul
(3,324 Views)
Hi Paul,
I wasn't able to find any C# examples for you but I did find some resources that may help you get started.
Is the LabWindows/CVI DLL written? If not, you can find information on building one in the following application note:
http://zone.ni.com/devzone/conceptd.nsf/webmain/A32E309A55A45CA08625686900623295?OpenDocument
I had a search around on Google and found the following example on how to call a C++ DLL in C# which you could try modifying:
Good luck with it,
SarahB
NI | UK
Sarah
Applications Engineer | National Instruments | UK & Ireland
(3,304 Views)
The dll is already written.
I was having one of those days yesterday where I went with an initial assumption and stuck with it (that I should pass the delegate to the dll).
This morning I had a 'light bulb' moment when I noticed that it required a uint for the callback which was an id to a registered windows message, Now I have working code by using the following pieces of code
1) override the wndproc function to look for messages that I need to handle.
        protected override void WndProc(ref Message m)
            if (m.Msg == m_comms.CALLBACK_Acq)
                m_comms.OnAcqStatusCallback(ref m);
            base.WndProc(ref m);
2. Register a callback message
            CALLBACK_Acq = RegisterWindowMessage("ACQCALLBACK");
3.  Unpack the returned LParam pointer.
        public void OnAcqStatusCallback(ref Message m)
            ACQMgsStruct amsg = (ACQMgsStruct)Marshal.PtrToStructure(m.LParam, typeof(ACQMgsStruct));
Regards
Paul
(3,300 Views)
