04-05-2006 08:58 AM
04-06-2006 09:51 AM
Hi Paul,
I wasn't able to find any C# examples for you but I did find some resources that may help you get started.
Is the LabWindows/CVI DLL written? If not, you can find information on building one in the following application note:
http://zone.ni.com/devzone/conceptd.nsf/webmain/A32E309A55A45CA08625686900623295?OpenDocument
I had a search around on Google and found the following example on how to call a C++ DLL in C# which you could try modifying:
Good luck with it,
SarahB
NI | UK
04-06-2006 10:15 AM
