LabWindows/CVI
can i edit a string on a text message control progratically ?
I want to know can I  edit a string on a Text message and update it programatically ( i.e erasing and then editing) .Plz reply .
Subrata
(3,067 Views)
You can change the text programmatically in a Text Message control by using code along the following lines:
    char line [256] = "Some new string data";
    SetCtrlVal (panel_handle, PANEL_TEXT, line);
If you need the operator to edit the text directly, rather than generate new text within your program, it might be better to use a String control.
JR
(3,062 Views)
