LabWindows/CVI
HOW CAN I EDIT A STRING IN TEXT MESSAGE AND DECORATION ?
 I am new to LabWindows / CVI .I want to edit a string to a Text Message with a particular colour . I also want to know can I edit a string on a decoration  box . Plz reply me as early as possible .
with Regards
subrata
(3,021 Views)
You can change the colour of text in a Text Message control by using code along the following lines:
    SetCtrlAttribute (panel_handle, PANEL_TEXT, ATTR_TEXT_COLOR, VAL_RED);
(Use ATTR_TEXT_BGCOLOR to change the colour of the background.) There is a choice of standard colours, or you can make your own if you prefer. There is no text associated with the Decoration controls.
JR
(3,017 Views)
