LabWindows/CVI
wav record
I am trying to record a waveform in a wav file. If i play the waveform with the VI  Labview the quality of the sound is ok but when i try to make the wav file the quality is not ok. I attached the file i want to save as a wav file and the VI i programmed. Thanks a lot!
Another question: There is any way to stop playing the waveform (or stop the program) when it enters into the "Play Waveform.vi"?
Thank you very much
Javier
(3,479 Views)
Hi Javier!
   You are in LabWindows forum... maybe you'd better post on LabVIEW! Smiley Wink
   Have a nice day!
graziano
(3,475 Views)
