LabWindows/CVI
can i use dll which is created in BC++ in cvi5.0 without lib?
I have a dll created in BC++,I want to use it in cvi,when i choose
Option->generate import libary,cvi always tell me dll is damaged.Is it
possible for me to use dll without lib? or can i use the former lib
created by BC++?
Hope any help!
(3,366 Views)
Yes, you should be able to use the DLL in CVI, as long as you have C functions in it, not C++ since CVI is a C compiler. You would use LoadLibrary and GetProcAddress to load the DLL and call the functions. See the Windows SDK help for more information.
Best Regards,
Chris Matthews
(3,366 Views)
Dear Chris Matthews :
Thank you very much for your answering.
I want to ask you another question,when cvi generate lib for my
dll,cvi tell me dll is damaged,but my dll is not damaged because I can
use it in BC++.
It can generate lib for another dll,but the funtion is not in the
dll.I am confused,could you give me some advices?
Thank you!
(3,366 Views)
TO use a CVI-generated DLL in CVI, you'll have two projects. To the project where you built the DLL, you need to add a .h file which has the prototypes for all the functions you want to export (make available to other applications). You also need to select that .h file under Build >> Target Settings >> Exports >> Change (using CVI 6.0 menus). Then, to the project from which you'll call your DLL functions, you need to add the .lib file from your DLL project.
(3,366 Views)
There are several reasons the import library generation could fail. There could be data types causing the problem, or C++ features like function overloading.
Chris
(3,366 Views)
