LabWindows/CVI
change published labview file
Hi i have a published labview file. But i need to see how the protocol is implementet (a coworked that was fired and got mad, deleted everything except the published material from the server). Could anyone please guide me, what i'm especially interested is in it's communication via. rs-232.
thank you in advance
(3,226 Views)
Hi aterra,
I'm not absolutely sure, what you mean by published LabVIEW file. Could you please explain this? If you could also give me some details about your hardware and software, it would be a great help.
Peter
AE DK
Message Edited by Posse on 03-13-2006 03:55 AM
Peter Porsman | Applications Engineer | National Instruments
(3,189 Views)
Hello attera,
If you are referring to publishing your VIs on the web (remote front panels), I would suggest checking out the following thread.
Wendy L
LabWindows/CVI Developer Newsletter
(3,166 Views)
