child panel is never shown
I am working with LabWindows/CVI 6.0 under Windows XP.
I would like to set "panel2" as a child panel to "panel1" and show both of them at program start on the screen. I defined both panels in one uir-file "test.uir". I call this code:
if ((panel1Handle = LoadPanel (0, "test.uir", PANEL1)) < 0)
    return -1;
if ((panel2Handle = LoadPanel (panel1Handle, "test.uir", PANEL2)) < 0)
    return -1;
DisplayPanel(panel1Handle);
DisplayPanel(panel2Handle);
However, "panel2" is not shown after executing this code, even if I call "SetActivePanel(panel2Handle)" after "DisplayPanel" it doesn't change its behaviour. What am I doing wrong? What do I have to do to show both panels?
Thanks in advance,
junimond
(2,988 Views)
junimond,
One possibility is that the panel is there, but is scrolled outside of the bounds of the parent panel. By default, the initial position of a panel, relative to its parent (or the screen, in the case of a top-level panel) is the same as it was in the User Interface Editor. Therefore, try to move the child panel closer to the top-left of the editor window, and see if it makes a difference. Another alternative is to check the "Auto Center" options in the Edit Panel dialog.
Luis
(2,974 Views)
