09-13-2012 02:37 AM
@LuisG wrote:
I don't mind investigating the reason for the crash
Hi Luis,
that's nice to hear
and I hope that you will be successful in reproducing the problem - I have uploaded a file called clang_issues.zip which hopefully contains all necessary files for compilation, including the ecc - if I missed one, PM me. To reproduce the issue, load the project, select release configuration with the ecc file provided, and start compilation, it should crash the first time at file CSI Delta...
Concerning documentation... I'll add a few thoughts:
09-13-2012 04:01 PM
Unfortunately, I haven't been able to reproduce the crash. All CSI Delta*.c files compiled successfully.
However, the project as a whole did not build, because of a missing file. So, I can hold out hope that once I have that file, something might change that causes the crash to occur.
I'll continue this via PM. Once we have some conclusion I can post a summary here.
Luis
09-20-2012 02:00 AM
Just for (my own) reference: the compiler crash has also been observed at NI and been awarded a CAR: 371554
