clang error using using _TARGET_PRODUCT_VERSION_: invalid suffix
I want to display the current version of my software on a string control, using _TARGET_PRODUCT_VERSION_.
This works fine with the internal compiler, but when switching to clang 2.9 I receive an error:
error: invalid suffix '.0.114' on floating constant
(the _TARGET_PRODUCT_VERSION_ translates to 3.0.0.114)
Ideas? Thanks!
(4,491 Views)
Accepted by Wolfgang
Yes, this is a known-issue (371655), as of 3 weeks ago. You're not able to use a pre-defined string macro in your code when using any third-party compiler. It's already been fixed internally, but unfortunately I don't think there's any workaround other than waiting for the fix to be available.
Luis
(4,451 Views)
Thanks for the confirmation...
By the way, could this be an option for the NI update service?
(4,448 Views)
NI Update Service only plays a role when a new version (service pack, etc...) of the software is available. So, when a version that includes this fix is released then, yes, you should receive an update service notification.
(4,441 Views)
@LuisG wrote:
So, when a version that includes this fix is released then....
I vote for this year Smiley Happy
(4,435 Views)
Point taken Smiley Wink
By the way, looks like I gave you the wrong bug #. It's actually 368271.
Luis
(4,421 Views)
I am happy to see that this has been fixed in CVI 2012 SP1
(4,208 Views)
