LabWindows/CVI
comment avoir un "File Path Ctrl" ?
bonjour,
je voudrais savoir comment obtenir un control qui va me selectionner un chemin de repertoire comme dans LabView avec son "File Path Ctrl".
mon but étant de selectionner un répertoire ou j'irai chercher le contenu.
mes considérations,
Cordeiro Joel
Kodak Trophy
Message 1 of 10
(4,606 Views)
If I am not wrong, you are looking for the ability to browse the disk and select a file and/or path. You will find very useful for this the FileSelectPopup and DirSelectPopup commands located in the User interface library.
Message 2 of 10
(4,596 Views)
thanks,
but, can y do that whith a control in a panel whithout a popup ?
Message 3 of 10
(4,592 Views)
Well, in CVI 7 there is a file browser control that you can locate in one of your panels to browse the disk. In preceding versions of CVI you'll have to write your own piece of code or find a third party control to do it.
Message 4 of 10
(4,590 Views)
OK, so will do with a popup.
thanks for all.
Message 5 of 10
(4,590 Views)
@cordeiro wrote:
bonjour,
mes considérations,
Cordeiro Joel
Kodak Trophy
I have also done this, as you have expressed, from a control on a panel, without using a popup. But it was not simple. I used a combination of ring controls and radio buttons to get user input. The ring controls programmatically keep a history of its user's previous selections (through use of updating an ini file with a path/filename string entry), the last item on the ring is always set to "browse". If the user selects "browse", the resulting callback contains a collection of functions that search for files of a certain extension type, down directories with certain characteristics. (user sets radio buttons prior to using ring control to set kinds of directories, or file extensions.) As you may imagine, this required some time and effort, but was all fairly straight forward code. The FileDirectoryPopup is much quicker to emplement.
Message 6 of 10
(4,583 Views)
Hello, and thanks,
yes, it's not simple !
so, I will do with a popup, I haven't time now to do that from a control on a panel.
I thinked it was a fonction already maked.
thanks for all, goodbye.
Message 7 of 10
(4,570 Views)
Hello
I'm using CVI7
can you give me the location of file browser control please?
Message 8 of 10
(4,419 Views)
You can place a file browser control on your UIR by right-clicking on the panel and selecting Custim controls >> Toolslib controls >> Fie browser in the context menu.
The control works in conjunction with FileBrowser.fp instrument, located in <cvidir>\toolslib\custctrl directory.
Message 9 of 10
(4,410 Views)
I've found it
thank you roberto
Message 10 of 10
(4,404 Views)
