LabWindows/CVI
comment convertir la fonction to_number on labwindows
Bonjour,
j'ai un algorithme qui comporte la fonction to_number :
intCheckSum = to_number(substr(strNumSerie, 1, 1), '9');
j’ai trouvé cette fonction on labview, mais je n’arrive pas à le traduire on CVI.
Merci pour votre aide
(3,651 Views)
There are a lot of conversion functions in CVI (as in every C compiler): some of them are grouped in ANSI C Library >> General utilities >> String to Arithmetic expression (functions like atoi, atof...). Alternatively you can scan number from string with sscanf (ANSI C library >> Input/Output >> Formatted Input/Output) or Scan (Formatting and I/O Library).
CVI and LabVIEW are very different: for the first one some time spent looking into libraries or checking some good C programming manual would help Smiley Wink
(3,644 Views)
bonjour,
il ne s'agit pas d’une simple conversion d’une chaine à un entier, la fonction to_number on le trouve en labview, PL/SQL…..
ci-joint quelques explications de cette fonction :
lien utile pour plus d'info:
http://www.dba-ora.fr/article-to_number-102614909.html
CDT
(3,632 Views)
moumou,
1. I'm sorry but I don't speak French: I'll keep on in English and rely on automatic translations to understand your posts unless you write them in English too
2. I don't understand if you are looking for a CVI function or for an explanation of a SQL statement. While I cannot help you for the latter, I suggest you to study Scan () function from the Formatting and I/O Library, which comes plenty of explanations and examples. As an alternative in standard ANSI C language you can use sscanf (), documentation for which can be found in any C reference book
If you can provide an example of the string to extract data from, we can try suggesting you some idea.
(3,614 Views)
Bonjour moumou,
J'ai trouvé quelques examples pour les fonctions «Scan».  Regarde ces examples et dites-moi si ce n'est pas l'idée correcte.
Daniel Dorroh
(3,607 Views)
...and this link works Smiley Wink
(3,601 Views)
