LabWindows/CVI
communication série avec interruption
Bonjour,
je suis novice en Labwindows CVI et je cherche un exemple de communication série en utilisant une interruption en reception
Merci.
(3,289 Views)
You can serach among the examples shipped with CVI: samples\rs232\commcallback.cws is a program that uses InstallComCallback to install an asyncronous function executed in interrupt.
(Sorry for not answering in French: you may post in the French board or you can write in English into this board)
(3,281 Views)
Think you for your response.  We don't have problems with the langage used  and think you one more time.  (it works)
(3,274 Views)
