LabWindows/CVI
context help default window at launch
Hi
When the context menu is launched it defaults to help.jpg (attached).
I would like to define this initial window and also only show help for those controls that have a description.
I don't want the message "No Description available" - maybe I just have to have a desciption for everything?
Any simple solutions?
Al
(sorry please could someone move this post to the LabVIEW forum
I used the browser back button and this setting wasn't remembered)
Message Edited by Al1234 on 01-14-2009 05:19 AM
(3,593 Views)
Accepted by Al1234
Morning.
Unfortunately you are not going to be able to change the default page on the context help or the information it displays. The Context Help is effectively going to be a password protected VI that does not expose aany properties, therefore you will not be able to make any changes to it. I think yor best solution is going to be making sure that everything has an associated description.
Rich
NI | UK
(3,570 Views)
