LabWindows/CVI
convert string to a number
I have an instrument with a serial output. The output string is   X=+03.22 CR LF Y=-04.22 CR LF.  I need to extract the two numbers.
I have been trying to use strtod in the stdlib. Is there an example code showing how to make and use character strings?
(7,012 Views)
you might consider scanf instead. Refer to userint\standardio.cws for an example of using the scanf function.
(7,011 Views)
Accepted by topic author Jim Rogers
If this is the only thing your instrument sends out, X and Y values one after the other, then you can do this:
char buffer[16];
double valX, valY;
ComRdTerm (port, buffer, 15, 13); // 13 = CR byte value
valX = atof (&buffer[2]);
valY = atof (&buffer[2]);
S. Eren BALCI
IMESTEK
(7,002 Views)
Thanks for the help. Atof fixed the prob
Jim R
(6,990 Views)
I need to correct my code a little. In order to atof work correctly it must see a null character to understand where the string ends.
Here is the corrected version.
char buffer[16];
int len;
double valX, valY;
len = ComRdTerm (port, buffer, 15, 13); // 13 = CR byte value
buffer[len] = 0;
buffer[len] = 0;
S. Eren BALCI
IMESTEK
(6,970 Views)
Sorry... Smiley Wink but I would suggest one more (minor) change
char buffer[16];
int len;
double valX, valY;
buffer[len] = 0;
buffer[len] = 0;
(6,966 Views)
Thank you Wolfgang, I had forgotten to put it there...
Now we have a complete code!... 😉
S. Eren BALCI
IMESTEK
(6,961 Views)
