LabWindows/CVI
how to write last 48bits of a bouble variable
hi,
i would like to know how to write last 48bits of double type variable. i am trying create a certain memory format. it needs a 48bits of a one data point. since we C doen't have 48bit variable i created double variable. now i am trying to write last 48bits of this double.(most significant bits). any help would be appreciated.
(3,443 Views)
Double variables are treated by CVI according to IEEE 754 standard, which means the 64 bits are organized in groups to represent sign, exponent and mantissa of a floating point library. For this reason it seems to me that you may come into troubles by attempting to use some bits only of a double variable.
If you are not treating floating point numbers, you may consider to use '__int64' data type instead which is supported by CVI starting from release 7.0 on or the equivalent 'long long' data type introduced in CVI 8.5: both describe 8-bytes integers.
(3,441 Views)
Thanks for the reply Roberto. If  i use '_int64' data type how can i get last 48bits of that data type to write to the disk? Or  does labview support integer 48bit data type? the memory format i am trying to create requires this data to be 48bits.
(3,429 Views)
I'm not aware of any 48-bit data types so you'll have to make do with something like three short types.  Something like this should work (from the interactive execution window):
static double d64 = 1234567890.0;
static short *s;
static short first16, second16, third16;
s = (short *)(&d64);
first16 = *(s + 0);
second16 = *(s + 1);
third16 = *(s + 2);
DebugPrintf("%d, %d, %d", first16, second16, third16);
 Where the short ints first16, second16, and third16 will give you the first, second, and third set of 16 bits from the double, respectively.  I have no idea how to do that in Labview.  Please note that this is the Labwindows forum.
(3,417 Views)
