copy file to desktop
How can i copy a file to Desktop? How to find the pathname to users Desktop (multi-language)? is there a special variable like %USERPROFILE%?
(4,075 Views)
Accepted by karpa
To get the desktop location use the Windows API SHGetKnownFolderPath or SHGetFolderPath as described in this thread. The names of the paths you can retrieve (like Desktop, AppData, My Documents etc are listed here.)
--Ian
(4,067 Views)
so i dit try the suggested sollution but is producing an error..
#include <shlobj.h>
SHGetFolderPath (0, CSIDL_DESKTOP, NULL, SHGFP_TYPE_CURRENT, path);
  link Error: Undefined symbol '_SHGetFolderPathA@20' referenced in "launchexe.c".
i used it inside launche.exe example
win XP cvi 8.5
Message Edited by karpa on 01-02-2010 09:36 AM
(4,056 Views)
Have you added Shell32.lib to your project?
(4,042 Views)
 I added the lib from an older project of mine, i changed it with the one from cvi sdk and everything works now!
Thanks!!
(4,031 Views)
