LabWindows/CVI
copy .txt file from VPN network
I want to copy .txt file from VPN network. Anyone can tell me how?
thanks
(3,099 Views)
Good Morning Popcorn,
Could you please give me some more information about what your application will be doing here?
For example, are these text files going to be at a network location and you will simply be writing a CVI program to move them to your personal computer?
Or possibly they are on a computer and you are wanting to transfer them to another computer on the LAN (in which case a TCP communicator might be the best solution).
Also, which version of LW/CVI are you using? Base development or Full?
Please respond with this information so I can further assist you.
With warm regards,
David D.
(3,056 Views)
