LabWindows/CVI
Showing results forย
Search instead forย
Did you mean:ย
create DAQmx task
Hi, i have a probem that when i click the creat DAQmx task in the menu "tools", it look like the CVI doesn't have any response! can someone help me?
thanks!
(4,749 Views)
Hello Xiaoyiyi!
Could you specify some further details about your setup?
  1. What version and build of CVI are you running?
  2. I assume you are referring to the Tools ยป Create/Edit DAQmx Tasks... menu item? The functionality requires NI-DAQmx to be installed on your machine. Which version of NI-DAQmx do you use?
- Johannes
(4,748 Views)
