LabWindows/CVI
create DAQmx task
Hi, i have a probem that when i click the creat DAQmx task in the menu "tools", it look like the CVI doesn't have any response! can someone help me?
thanks!
(4,739 Views)
Hello Xiaoyiyi!
Could you specify some further details about your setup?
  1. What version and build of CVI are you running?
  2. I assume you are referring to the Tools » Create/Edit DAQmx Tasks... menu item? The functionality requires NI-DAQmx to be installed on your machine. Which version of NI-DAQmx do you use?
- Johannes
(4,738 Views)
