LabWindows/CVI
Showing results forĀ
Search instead forĀ
Did you mean:Ā
create a function in CVI
i can't have the input parameter RES after i build the DLL .
/********   INIT CAN Callback    **************/
char* init_can (int Port_CAN,char* RES)
unsigned   char target[20]={0};
   char msg[512] ;
 int state=0;
	 strcpy(DEVICE,"COM6");
	//TD=OpenComConfig(Port_CAN,DEVICE,57600, 2, 8, 1, 0, 0);   //COM pour la passerelle CAN
	TD=OpenComConfig(Port_CAN,DEVICE,9600, 2, 8, 1, 0, 0);
		if(TD != 0)
		    printf ("port not open\n" );
		  goto END;
      	FlushInQ(Port_CAN);
  FlushOutQ(Port_CAN);
		ComWrtByte(Port_CAN,0x88);
		ComWrtByte(Port_CAN,0x55);
		ComWrtByte(Port_CAN,0x06);
		ComWrtByte(Port_CAN,0x21);
		ComWrtByte(Port_CAN,0xC3);
		ComWrtByte(Port_CAN,0x3A);
		ComWrtByte(Port_CAN,0xFA);
		ComWrtByte(Port_CAN,0xF9);
	    ComRd(Port_CAN,Reponse,20);
		memcpy(target,Reponse,5);
        strcpy (msg, "String =");
		for (i = 0; i <5;i++)
		{ sprintf (msg, "%s 0x%X", msg, target[i]);
strcat (msg, "\n");
	printf(msg);
		 RES=msg ;
		if(Reponse[3]==0x41)
            printf (" INIT VITESSE CAN SUCCESS\n ");
		 state++;
  		 Delay(1);
		else
		  printf ( " ERROR CAN INIT VITESSE\n ");
		  CloseCom(Port_CAN);
		  goto END;
		FlushInQ(Port_CAN);
		ComWrtByte(Port_CAN,0x05);
		ComWrtByte(Port_CAN,0x20);
		ComWrtByte(Port_CAN,0xFE);
		ComWrtByte(Port_CAN,0x01);
		ComWrtByte(Port_CAN,0x07);
		ComRd(Port_CAN,Reponse,5);
		if(Reponse[3]==0x46)
		  printf (" SYNCHRO RS232 SUCCESS\n ");
		 state++;
		 Delay(1);
		else
		  printf ( " ERROR CAN SYNCHRO RS232\n ");
		  CloseCom(Port_CAN);
		  goto END;
		CloseCom(Port_CAN);
		OpenComConfig(Port_CAN, DEVICE, 57600, 2, 8, 1, 0, 0);  // COM pour la passerelle CAN   115200
		FlushInQ(Port_CAN);
       //FlushOutQ(Port_CAN);
		ComWrtByte(Port_CAN,0x03);
		ComWrtByte(Port_CAN,0x2B);
		ComWrtByte(Port_CAN,0xF5);
		  printf (" TEST RS232 SUCCESS\n ");
		 state++;
		 Delay(1);
		else
	 printf ( " ERROR CAN TEST RS232\n ");
		  CloseCom(Port_CAN);
		  goto END;
		// INIT REGISTER
		FlushInQ(Port_CAN);
		ComWrtByte(Port_CAN,0x23);
		ComWrtByte(Port_CAN,0xFF);
		ComWrtByte(Port_CAN,0xFB);
		 //   RESET Can Reception Buffer
		FlushInQ(Port_CAN);
		ComWrtByte(Port_CAN,0x2D);
		ComWrtByte(Port_CAN,0xF3);
		  //Time maxi beetween 2 char is 200 ms ( on RS232 link)
		FlushInQ(Port_CAN);
		ComWrtByte(Port_CAN,0x04);
		ComWrtByte(Port_CAN,0x2E);
		ComWrtByte(Port_CAN,0x14);
		ComWrtByte(Port_CAN,0xE3);
		 // Can Message not acknowledge request
		FlushInQ(Port_CAN);
		ComWrtByte(Port_CAN,0x29);
		ComWrtByte(Port_CAN,0xF7);
		if(state==3)
      printf (" CAN INIT SUCCESS...PLEASE PRESS BSI ON\n");
        else
      printf ( "ERROR CAN INIT\n");
END:
   return RES;
Message 11 of 32
(2,895 Views)
I suppose this is because you are assigning to RES the address of the variable msg which is local to the function and at its end it is no more valid. Try with memcpy instead.
Message 12 of 32
(2,893 Views)
i try it but still doesn't work any other suggestions please
Message 13 of 32
(2,893 Views)
Accepted by ahmedkochbati92
This structure works in a compiled executable:
char * myFunction (char * msg)
  char  buf[32];
  // Manipulate the string
  strcpy (buf, "Hello world!");
  // Save the string
  strcpy (msg, buf);
  // Return the string
  return msg;
I never tried to do the same in a DLL and I cannot test it now, but I suppose should work as well.
Message 14 of 32
(2,895 Views)
still have the same problem i can't have the Input /Output paremeter  RES after i build the DLL als here the buffer type is unsigned char not const char so alawys i have an error with strcpy .
i need this function to return the paremeter msg
char*  init_can (int Port_CAN, char* RES )
   char msg[512] ;
 int state=0;
		if(TD != 0)
		  goto END;
      	FlushInQ(Port_CAN);
strcat (msg, "\n");
	printf(msg);
		  strcpy (RES,msg);
		 state++;
  		 Delay(1);
		else
		  CloseCom(Port_CAN);
		  goto END;
		FlushInQ(Port_CAN);
		 state++;
		 Delay(1);
		else
		  CloseCom(Port_CAN);
		  goto END;
		CloseCom(Port_CAN);
		FlushInQ(Port_CAN);
		 state++;
		 Delay(1);
		else
		  CloseCom(Port_CAN);
		  goto END;
		// INIT REGISTER
		FlushInQ(Port_CAN);
		FlushInQ(Port_CAN);
		FlushInQ(Port_CAN);
		FlushInQ(Port_CAN);
		if(state==3)
        else
END:
   return RES ;
i try to call this DLL from Teststand and Labview and still the same problem
Spoiler
Message 15 of 32
(2,879 Views)
Well, since your problem lies in the interaction between CVI and TestStand, it seems to me that the best place where to ask is the TestStand board. There are several discussions there on this subject, look for example at this aswer from Josh and the KnowledgeBase article he links. Hope this makes sense for you, it doesn't for me as I'm not using TestStand.
On the CVI side, I don't understand why you don'use ComWrt and use a series of ComWrtByte instead. And finally, I suggest you to pass -1 to OutputQueueSize in OpenComConfig in order to exclude the use of the output buffer in serial communication and have a more responsive system.
Message 16 of 32
(2,877 Views)
thank you for your response
i tried to import the DLL in Labview and it work
in the CVI side i change only the return type of the funcyion in char*
Message 17 of 32
(2,878 Views)
Hi Mr Roberto
i have problem with this function i can't read the true value of the received frame
this is the function :
PSA MODE
RAZ Buffer Reception Can
CAN :->88 55 03 2D F3
CAN : Envoi DIAG ON CAN Frame 2.A
CAN :->88 55 0E 22 07 65 08 02 10 03 FF FF FF FF FF 75
CAN : Demande Nb Message Can
CAN :->88 55 03 2C F2
CAN6 :<-88 55 05 47 00 00 9F :OK
CAN6 :<-88 55 05 47 00 01 9E :OK
CAN : Demande Message Can
CAN :->88 55 03 24 FA
CAN6 :<-88 55 09 40 06 65 03 02 50 03 A5 :OK
CAN -> N° message Can1
CAN :<-025003A5 : OK   (  i want the fuction to return this value )
	  //PSA_MODE
	char*  PSA_MODE  (int Port_CAN )
 char msg[512];
		//1
	 	FlushInQ(Port_CAN);
		//2
	 	FlushInQ(Port_CAN);
		ComWrtByte(Port_CAN,0x0E);
		ComWrtByte(Port_CAN,0x22);
		ComWrtByte(Port_CAN,0x65);
		ComWrtByte(Port_CAN,0x08);
		ComWrtByte(Port_CAN,0x02);
		ComWrtByte(Port_CAN,0x10);
		ComWrtByte(Port_CAN,0x75);
		//3
	 	FlushInQ(Port_CAN);
		ComWrtByte(Port_CAN,0x2C);
		ComWrtByte(Port_CAN,0xF2);
	if(Reponse[3]==0x47)
		  printf ("PASSED_1 \n ");
		 Delay(1);
		else
		  printf ( "NOT_PASSED_1 \n ");
		  		//3'
	 	FlushInQ(Port_CAN);
		  printf ("PASSED_1' \n ");
		 Delay(1);
		else
		  printf ( "NOT_PASSED_1' \n ");
	   	//4
	 	FlushInQ(Port_CAN);
		ComWrtByte(Port_CAN,0x24);
		memcpy(target,Reponse,10);
        strcpy (msg,"");
		for (i = 0; i <10;i++)
		{ sprintf (msg, "%s%X", msg, target[i]);
strcat (msg, "\n");
	printf(msg);
		if(Reponse[3]==0x40)
		  printf ("PASSED_2 \n ");
		  Delay(1);
		else
		  printf ( "NOT_PASSED_2 \n ");
	  	return msg;
Capture01.PNGthis the result any help please
Message 18 of 32
(2,780 Views)
'msg' variable is local to the function and is released after the function ends, which means the caller can receive an invalid string. Have you tried passing the string to manipulate to the function as I told you before?
Try doing so and see if the string is correctly returned calling it from CVI: if it works, then the problem is likely to lie in how the function is defined in TestStand, which I cannot discuss.
Message 19 of 32
(2,774 Views)
Thank you for your response
This is my try but still doasen't work, i can't undrestand how it works in the Init can Function and no in this one
After i build the dll i'm calling it from labview it works properly in the init function return the msg received without adding a new paremeter like Input /Outpout  RES
	  //PSA_MODE
	char *PSA_MODE  (int Port_CAN ,char* RES)
 char msg[512];
		//1
	 	FlushInQ(Port_CAN);
		//2
	 	FlushInQ(Port_CAN);
		//3
	 	FlushInQ(Port_CAN);
		 Delay(1);
		else
		  		//3'
	 	FlushInQ(Port_CAN);
		 Delay(1);
		else
	   	//4
	 	FlushInQ(Port_CAN);
        strcpy (msg,"");
strcat (msg, "\n");
	strcpy(RES ,msg);
	printf(msg);
		  Delay(1);
		else
	  	return RES ;
Message 20 of 32
(2,768 Views)
