LabWindows/CVI
create application without administrative right
I want to use a release application, I created using CVI, on a different computer.  However, the other computer complains "This application has failed to start becasue cvirte.dll was not found.  Re-installing the application may fix this problem."  I don't have administrative right on this other computer.  Is there a work around to this?
Gary Z.
(3,129 Views)
Hi Gary,
You can't just copy your CVI built application over to another computer and expect it to run. This is because you need to install the CVI Run-Time Engine on that target computer. In this case, the CVI EXE can't load up its dependent CVI RTE DLLs because they don't exist on that target computer. cvirte.dll is one of the core CVI RTE components.
The best practice would be to build a installer that included your EXE as well as the CVI RTE.
Best Regards,
Jonathan N.
(3,126 Views)
