LabWindows/CVI
searching only project files
i have been using cvi starting with 7.1 and always disliked the search feature. i have never found a way to automatically limit searches to project files. does version 8.5 have this feature and if not why not? is there a better way that i am missing or is ni using a different concept of "project" this i am used to.
thanks
(2,879 Views)
> searches to
> there
Same here. I've always wondered why it insists on searching the whole
windows .h files if all you want are your own project files. Annoying.
Guillaume Dargaud
http://www.gdargaud.net/
"When you're hungry, eat.
When you're tired, nap in a sunbeam.
When you go to the vet, pee on your owner." - Cat philosophy (Gary
Smith).
(2,854 Views)
This is a good suggestion to perhaps add the option to search the files within the given project without needing to configure the individual "Multiple Files" in the Search window.  I will recommend this to R&D as a product suggestion.
Andy McRorie
NI R&D
(2,829 Views)
