creating panel
Hi I need to create a panel and code it, here i have (checkable/uncheckable) boxes, there will be total 170 boxes if i select any one box out of 170 boxes class should be on(checked/ticked). if i have not selected any boxes out of 170 boxes class should be unchecked.
sorry for my poor English,
please give me ideas or examples to do it.
i have attached the dummy panel snap
(3,313 Views)
Anyone??
(3,290 Views)
Accepted by vinaypooja
For such a large number of controls you may want to consider using a control array, you can read more about this feature here
(3,259 Views)
Thanks Wolfgang, I solved it using list box option. Thank you for advise.
(3,256 Views)
For such a large number of controls I would suggest creating them programmatically: create a panel with a single checkbox and iterate rows*column with DuplicateCtrl. CVI is good at this and that command simplifies a lot the task of creating large numebr of identical controls.
A single callback on all checkboxes could manipulate a static variable adding or subtracting 1 at every commit event. Such counter could then be used to mark appropriate checkbox 'non marked' / 'some marked'
(3,221 Views)
