LabWindows/CVI
cvi 64bit exe and sql toolkit
Hi all
I am using CVI 2013 SP2 and SQL toolkit 2.3 on win7 64bit machine
In order to connect to *.mdb file i use the following statement
hdbc = DBConnect("DRIVER=Microsoft Access Driver (*.mdb);DBQ=c:\\Temp\\Sampl.mdb") ;
When ia compile & run as 32bit exe it works
When ia compile & run as 64bit exe i get the following:
0x00000FEC:   Function DBConnect: (return value == -10 [0xfffffffffffffff6]). Native error code -2147467259 0x80004005 Microsoft OLE DB Provider for ODBC Drivers:     [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
Any help will be appreciated
Thanks for advance
Gabel Daniel
(3,978 Views)
Hi Gabel,
Are you using the 32bit version of odbcad32.exe or 64bit? This might be because you did not install the 64 bit ODBC driver.
This might be a helpful link: http://digital.ni.com/public.nsf/allkb/E7984C0DA0F0E65086257694005B4CB7?OpenDocument
I hope this helps!
T. Le
Vision Product Support Engineer
(3,939 Views)
Hi T. Le
Thanks for the reply
I have already checked the link you suggested with no luck
you can try the sample that come with the sql toolkit "connect".compile it as 64 bit exe & run it
it will no work.Further more you can not set DSN for *.mdb in the odbc32.exe (the 64bit version).
I resolved my immediate problem by writing all my sql staff in separate 32bit exe. That app communicate with my main 64bit app via shared memory.
thanks
Gabel Daniel
(3,933 Views)
I can read in the readme file for SQL Toolkit 2.3 (which appears to be not available on NI site but should be installed on your machine):
Note   To run example programs in 64-bit mode, you must use a 64-bit Microsoft Access driver, which is not included with the LabWindows/CVI SQL Toolkit. You can download the Microsoft Access Database Engine Redistributable, which includes drivers you need to run in 64-bit mode, from the Microsoft website. Note that the 64-bit driver cannot be installed concurrently with 32-bit versions of Microsoft Office.
As I can understand, you don't have a 64-bit driver installed and that's why you cannot run 64-bit examples. the link given above points you to Microsoft site where to download the appropriate driver.
(3,929 Views)
Hi Roberto
Thanks for the help
It was very helpful
Gabel Daniel
(3,925 Views)
