LabWindows/CVI
cvi 9.0 build error
Dear All,
I have application built early version (CVI 8.5). Now  I have modified the coding to add few facilities. But while building the application the screen appears as attached file. When I have deveoped the application I have used NIDaqV7.5.
Now I have V8.6 in my laptop installed.
If I do not include the NIDAQmx8.6. The build is OK.
What should do now.
Kumar.E
(3,081 Views)
This dialog is not reporting an error. It is just reporting that several disks will need to be provided during the distribution build process. In order to distribute the same versions of the components that are installed on your machine, it is often necessary to provide several different source disks. If you cannot provide those specific disks, you can press No, and the dialog may be able to suggest a different set of source disks.
Mert A.
(3,062 Views)
