cvi command to display data in command prompt
do we have any CVI command to display a specific data in cmd(command) prompt??
(4,081 Views)
Accepted by surabhi_bhosale
A simple printf will display data in the standard I/O window, more or less what you are looking for, while scanf will accept and elaborate user input in that window.
A bit of personalizatio for the standard I/O window is permitted via SetStdioWindowOptions () command: in the help for this command an example program is linked (userint\standardio.cws) that shows some interaction with the window.
(4,072 Views)
Thankyou 🙂
(4,061 Views)
