LabWindows/CVI
cvi odbc
I'm attempting to bind CVI to an ODBC server (IBM iseries DB2).  I have CVI FDS 7.1 with SDK loaded.  I have the iseries ODBC with administrator loaded.  Do I need the CVI SQL toolkit upgrade to implement?  And if so can I get an evaluation period?  Is there NI guidance documentation posted somewhere?
(4,235 Views)
bjasper,
To connect to a database using ODBC, you do have to use the LabWindows/CVI SQL Toolkit.  You can evaluate the toolkit by installing the evaluation version here: http://joule.ni.com/nidu/cds/view/p/id/1006/lang/en .  This is a full version of the toolkit, but the license expires after 30 days.  If you want to purchase the software after or during the evaluation period, you will receive the disks and the serial number used to activate the unexpiring license file.
Eric B.
(4,212 Views)
(4,205 Views)
Al,
That is good to note.  I hadn't thought about using that method.  You can definitely do that, but I haven't tried it myself.  The toolkit provides examples and function panels for the functions, which the Windows DLL would not provide, but you can definitely try the MDAC option.
Eric B.
(4,203 Views)
Thanks for the links...this should keep me busy for a while.
(4,200 Views)
