LabWindows/CVI
cvi teststand debug not working
I think you said you are using CVI7.1, have you installed the patch, http://digital.ni.com/softlib.nsf/websearch/361DFA46AE788E6A86256F56004D90DB?opendocument&node=13207...
Regards
Ray Farmer
Regards
Ray Farmer
Message 11 of 21
(2,535 Views)
Ray,
I deleted the cvibuild.Testexec folder and rebuilt the project but it still behaves the same way. I downloaded the patch you pointed me to and installed it, rebooted, rebuilt and still the same.
Does the output I attached in my first post provide any clues?
John Hopkins
Message 12 of 21
(2,527 Views)
Hi John,
Sorry, no it doesn't.
Is you project large, is it possible to zip it up and email or post on the forum.
Regards
Ray Farmer
Regards
Ray Farmer
Message 13 of 21
(2,522 Views)
Ray,
My project is fairly large but remember that I can duplicate all of this behavior using the NI simple testexec without reference to any of my code.
John
Message 14 of 21
(2,515 Views)
John,
Ok, can you remember what you were previously doing before it all stopped working.
Regards
Ray
Regards
Ray Farmer
Message 15 of 21
(2,512 Views)
Ray,
I work on several CVI projects at the same time but only one of them uses TestStand, so I had several CVI instances running. The only thing I really remember as being different is I installed the MS IE 7 beta.
John
Message 16 of 21
(2,508 Views)
John,
Are you able to try your project on another system or uninstall the IE7
Ray
Regards
Ray Farmer
Message 17 of 21
(2,501 Views)
Ray,
The project works fine on another system. The other system is CVI 7.0 rather than 7.1 but I don't think that is a big deal. I was thinking of reinstalling CVI 7.1 but I think your suggestion uninstalling IE 7 beta is much better. I will do that and let you know how it goes.
John Hopkins
Message 18 of 21
(2,487 Views)
Ray,
I uninstalled ie 7 beta and did a sfc /scannow to make sure everything was intact. The uninstall of the beta reinstalled my previous version of IE. However, nothing has changed with regard to my CVI problem. Perhaps I will just reinstall CVI 7.1.
John
Message 19 of 21
(2,481 Views)
John,
Any progress?
Ray
Regards
Ray Farmer
Message 20 of 21
(2,457 Views)
